100mm x 6 screws suitable for this TV ?
you have a 40mm plug and want to use a 70mm screw you will need a gap to accommodate the excessive screw length poking out the back off the plug so an excessively deep hole other wise the jacking out head twisting off or screw grounding i mention about will probably happen
my suggestion drill a 55mm hole knock the plug in 5mm below the surface take a screw that equals the bracket thickness plus plug depth so assuming the bracket is 6mm thick plus 45mm plug gives you 51mm so a 50mm/2" screw is perfect
remember it fine for a screw to only penetrate 5 mm short [35mm] as the load is approaching zero when divided between 4 wall plugs
When I put up this oven thing 17kg up it must put much more pressure on the screws than a thin tv as it's far from the wall so I chose 4 x 100mm 6mm screws in 8mm duo plugs. I thought being longer -100mm they'd be stronger but you think I was pointless to use such long screws? Should ve used 70mm x 6mm?
Don't have 50mm x 6mm or they don't exist dunno
you want 4.5 or 5mm 50-60 long assuming your bracket is between 3-8mm thick for brown plugs with a 6.5/7mm/1/4" masonary bit 50-55mm deep hole
not sure about your duoplugs you need to check
point to note
i have never used duoplugs so when i searched earlier it came up with 40mm so i assumed that was the only size i now realize they are in general big to very big hence the confusion with me assuming brown plug size with me refering to 4/4.5mm by 50mm and you keep refering to 70mm and 8mm :giggle:
... red plugs ...
... brown plugs ...
... red rawlplug ...
Nah - Fischer plugs are all the same colour (in each type - mostly grey) :LOL:
If he does mean Fischer DuoPower they're 5-14mm diameter (i.e. drill size), ≡ Rawlplug yellow/red/brown/blue/grey/bigger; and lengths (although obv not every one in each diameter) 25 - 80mm, ≡ Rawlplug.... err.... no choice; and screw diameter 4-12mm, ≡ Rawlplug 3-8mm.
I'm quite happy with Fischer SX or SX+ - doesn't bother me that they are all grey as they have the sizes moulded onto them. I've also got, but have yet to use, some DuoTec 10s.
But bring back the asbestos powder you used to mix with spit, that's what I say.
So I've just been using 6mm and 8mm fischer duos think 8mm plug is 35 or 40mm long and 6mm one shorter with all my screw fixings e.g 75mm and 100mm screws so no matter how long the screw. Think Big All said the plug should be same length as the screws not poking out the end? So what plugs do you recommend for longer screws e.g. 100mm/75mm?
4 inch screws for that TV? You sitting on it or watching it? Good grief.
I put a 65 inch TV up in an office and used 4 50mm pan head screws in brown plugs.
As Wayner said - why are you using such long screws?
Anyway - is 300mm long enough? ;)
There are many makes/suppliers - just search for wallplug strips (turn safe search on :oops: )
Think worried that 50mm penetrative into walls isn't enough and whatever was put up would fall down
The force is down not away from wall.
I just looked up and a brown plug will hold 86kg. That's 13.5 stone.
That would take my weight.
Now I used 4 screws so that's nearly quarter of a ton.
You ever tried to use a claw hammer to pull out a rounded screw? Takes some smacking and pulling damaging wall. Try one for interest or go buy a block and experiment.
Here is my glass fronted plasma at home. You can see one 40mm screw.
Not moved in 12 years.
