B
Big_Spark
ban-all-sheds said:Who's so in favour of regulations being followed even if they don't understand them that he thinks that Part P is b*11*cks and has no intention of using electricians because of it?
Who advises people to move their electricity meter themselves if the supplier asks £too much?
Who thinks that AC means that the neutral conductor is at 240V 50 times a second, and when people tell him he's wrong he accuses them of being mad?
Surely not....
My first post will be a bit controversial I think, but here goes in response to these comments.
Many parts of BS7671 (The 16th Edition Regs) are contradictory, vague and generally ambiguous at best. The IEE would not understand the term clear English if you droped a boat load of dictionaries of Faraday House. Having said that, if you bother to read the regs, and actually understand what they are saying, and you then carry out work as per they advocate, then you will at least be safe.
Part P...don't get me started on that load of unadulterated, self interested cr*p. Part P in the brain child of the NICEIC, which is a charity not a government body, and controlled, indirectly, by the big 4 in the contracting industry, T.Clarke's(Tommy Clarkes), Bailey's, AMEC, andMathew Hall.
I have personal experience of work from all of those, and most of their Guys I would not trust to wire a plug.
The concept behind part P is sound, however the joke that was the consultation, and the conclusions are very questionable.
The NICEIC and the ECA only have their own interests at heart, not that of the Industry or the public.
Moving your Electricty meter is a CRIMINAL OFFENSE. It is also an offense under the Electricty Supply Regulations Act and the Electricity Supply Act, however you will likely just be prosecuted by the the company for interfering with the meter, often called "Abstraction of Electricity" by the law.
Moving an Electricity meter is foolish.
AC..means ALTERNATING CURRENT, this also means the voltage alternates. 50 times a second the "Live" Phase conductor will be at a peak of around +338V (The RMS is 240V), further 50 times a second it will be at 0V and conversly it will be at -338V 50 times a second.
The same is true of the "Neutral" phase conductor, however due to the complexity of electricity, in an everday sense it is usual to think of it as "dead"..I won't bore you with the maths and technical reasons, but this is actually the case.
And if you think you cannot get a shock from the "Neutral" then you would be very wrong, just as you can get a shock from and "Earth" point or conductor if the circumstances are right.
HOWEVER, if you always turn the supply off to the circuit you are working on, then you will never recieve an Electric shock regardless.
