And there was me thinking that if two conductors have the same electrical potential, the potential difference is zero. And thus there is no energy transfer (First law of thermodynamics). And thus there is no relevance to power or power factors.
AdamW said:And there was me thinking that if two conductors have the same electrical potential, the potential difference is zero. And thus there is no energy transfer (First law of thermodynamics). And thus there is no relevance to power or power factors.
FWL_Engineer said:I'll write a big explanation later about all this, however suffice it to say I will post this.
NEUTRAL = EARTH= 0V THIS IS WRONG
Neutral and Earth ARE NOT ONE AND THE SAME, they just have the same electrical potential in a balanced supply with a unity power factor.
My previous post on this was worded VERY badly, confused the issue, and I posted a couple of bits that are actually wrong..I must have had my head in my proverbial ...sorry.
I will write a detailed explanation of all this tomorrow, I have to go out now.
FWL_Engineer said:Adam, whilst the potential difference between two conductors may be zero, thus at the same potential, that can change due to conditions and thus the PD will be +/- zero
Now, if they have the same potential, the potential difference MUST be zero. In which case in the Earth frame of reference then neutral DOES equal zero. Now, I know that in real life power supplies neutral doesn't = 0 with respect to earth, but I just thought I should perform my duty as a pedantFWL_Engineer said:Neutral and Earth ARE NOT ONE AND THE SAME, they just have the same electrical potential in a balanced supply with a unity power factor.
AdamW said:With respect to the evolution thermodynamics thing, it could be worse: some (perhaps all) states in america are only allowed to teach evolution as "a theory" and have to give equal weighting to creationist theory. What next? A european electrical college describing earth as "a theory" and giving equal weighting to flimsy inadequate cables?
FWL_Engineer said:ban-all-sheds said:But doesn't that higher rating come about because the insulation of the cable will tolerate a higher temperature? If you install a circuit such that it runs with a higher conductor temperature than you would encounter with normal T&E, can you be sure that the switchgear and appliance(s) will be happy at that temperature?
NO it does not, the higher current carrying capacity of SWA comes about due to it being Hard Drawn Annealed Multi-Strand, T&E is soft drawn Multi-stranded and not annealed, as a result it heats up quicker for a given load than the cores of SWA or even Pyro, the latter is also a higher grade of copper, this is why a Pyro of a given size will carry more load than any other cable.
ban-all-sheds said:Doesn't 3-core SWA have a lower rating than 2-core? Or is that only on the assumption of multi-phase currents?
3 Core SWA has a LOWER volt drop rating than 2 core.
According to table 4D4B, the volt drop of 3 core cables is consistantly lower than that of 2 core cables, HOWEVER, this is assuming the cable will be used on a 3 phase supply in the Regs.
This is something I will be speaking to the IEE about in a few minutes to shed some light on this particular point.
FWL_Engineer said:However, in the 20 odd years I have been in the trade, I have rarely come across borrowed neutrals. As far as I can recall, the only time they have been encountered is when correcting problems caused by DIY electricians, with one notable exception.
