It seems to depend where you read as to if 11.5 or 12 volt, but also there are a few points including the soft start feature, and the possibility of EMC problems with leads longer than 2 meter. But most high frequency power supplies are the same, swapping from a true transformer to a pulse width modulated power supply (electronic transformer) is only any good when the existing set-up complies with the requirements of the electronic device.
Two meters is not very long to connect 10 lamps there would only be 200 mm between each lamp. There is a huge difference between 35 kHz and 50 Hz and this includes what a coiled element inside to bulb will do with that frequency.
This
is what I call a transformer. However with a transformer what comes out is related to what goes in so in voltage 250 is going to mean brighter lights than in voltage 220 where with the electronic power supply any volt drop on the input is compensated for.
When we read the info sheets calling SELV safety extra low voltage rather than separated extra low voltage makes one think the writer did not really know what he was doing! But at least they do realise with cable length between 300 mm and 2 meters they are not suitable for any more than three lamps each.
Personally never liked SELV lighting the low voltage lamps (230v) are far safer and flexible, with less current in cables, less volt drop, bayonet connectors which will not allow the use of unsuitable lamps, and less to go wrong. Once converted to low voltage you can swap between tungsten, cold cathode and LED without problems.
