That really seems to me to be a 'back of a fag packet' design to me. It really isn't difficult to run 2 specific test around dynamic deliveries and that will provide a solid starting ground to which a practical and sensible design can be constructed. That coupled with what the district mains actually delivers. That is then coupled with the site specific requirements in the way of what is needed to satisfy the outlets and then add the clients 'requirements' .
It really isn't rocket science and to me the starting point is, what can the cold mains deliver to the property if the clients were using the outlets in a typical daily fashion and then balance that against peak possible requirements. With you it would be - if the washing machine was on and someone wanted to use hot water for dishes downstairs and at least 1 person was in the shower if not both were being used, what would the worst case be as far as supply needed to deliver that and how could that be done, if at all.
That then drives possible designs. To me it's not just about 'what's the biggest or most expensive boiler that can be jammed in there', it's more about the whole hot and cold water system design, especially where the mains seems to be as limited as yours may be.
