Hi.
I recently purchased a couple of 12volt MR11 light fittings with electronic transformers (Live & Neutral input, no earth).
I have connected them but every time I switch them on it results in half the Consumer Unit going off after tripping one of the 63A RCCBs. The individual 6A lighting MCB itself does not trip. I have two transformers and two light fittings and both combinations have the same result. If I take the load off the transformer, i.e. take the bulb out but leave the transformer connected the circuit it doesn't trip so no obvious short in the transformers.
The circuit is pre existing up to the transformer so I'm happy that's ok as it was switching mains voltage lights before without problems. It's a new build house so no old dodgy wiring.
Does anyone have any suggestions as to what may cause this?
Thanks.
Jas
Thanks.
Jas
