I just had an electrician tell me there would be no problem grinding a small channel for single drop lights in each room. This would be on condition I removed the artex surrounding the run. He said it would be so shallow it wouldn't impact structurally and he's done it before on many flats like mine.
Does this sound right? Bearing in mind the ceiling is concrete above what seems like quite a thin layer of atrex/plaster?
BS7671 says nothing explicit about routing cables in ceilings nor, AFAIAA about any considerations regarding protection of cables 'buried in/above ceilings' - it only mentions such explicit things in relation to walls. For cables below floors or 'above ceilings' there is only a vague statement (522.6.201) that they "...shall be run in such a position that it is not liable to being damaged..."Are there any zones in a solid ceiling?
All chases must be horizontal.Are there any zones in a solid ceiling?
Yes, indeed - but, as I said, all BS7671 has to say about that is a vague staement about "not liable to be damaged" - no regulations/requirements about 'zones' (which is what you asked about), protection of shallow-buried cables etc. etc. in the same way that there are for walls.I think you could reasonably interpret "below floors" and "above ceilings" to describe a cable recessed into a solid ceiling.
It can be. Even if not, it will be highly unpleasant messy work for someone.It doesn't sound a good idea to grind a channel in the ceiling - isn't that like notching the underside of a joist?
I can believe that. What about nailing/screwing into them to attach a suspended ceiling - is that likely to be permitted? (I suppose one could use adhesive!).Other considerations are that in many blocks of flats, cutting into ceilings or the floor is not permitted anyway, as that isn't considered to be part of the flat.
Hi again!
Sorry the main reason I was trying to avoid boarding over, is it basically doubles the cost in every quote I've had. In the region of 2k extra. I'm not looking to have spotlights or anything fancy, so it just seems a lot for the sake of 4 drop lights in 4 rooms and I'm on a tight budget.
Had another guy come today and he claims you must have the cables in a metal casing, so if I took the other guys advice, it wouldn't be up to regs. He said the cable would get eaten away over time, but that doesn't seem right to me. Seems every person I get a quote off, has a different story!
Anyway, I totally understand that boarding should be the way to go... just need to find a couple of grand laying around
Thanks again.
