In reply to the original question regarding PVC beying installed at the same time as VIR, then further to sparkwrights reply, yes, this did happen and is likely around very early 1960s installs. Seen one building where the cabling in the walls was PVC, but link wires on the back of switches between common terminals, etc where offcuts of VIR. Obviously the chap doing the second fixing either prefered it, or was using up offcuts from the bottom of his toolbag! Also seen VIR insulated cores in a PVC oversheath.
But.... looking at the photographs, the wiring looks later than this, it looks solid solid cores in the picture? Pre 1970 when cables were imperial, any conductor larger than 1/.044 (0.97mm) was stranded. On rings both the L&N and the earth would have been stranded. Earth on the ring circuits would have had three strands, the L & N seven. Even lighting would probably have been stranded, likely it would have been in 3/.029 (1.3mm) and would have had three strands, earth though (if present would just be one). Others will probably correct me, but I think twin 1/.044 may have been available for lighting? but not widely used.
If its solid cores on the ring, then look at the cpc. if its 1mm, it was installed in the 1970s, if it is 1.5 then after 1980 (anywhere upto 2004 when the red and black colours ceased being available).
The fixing through a loop of scrap cable was pretty common as an poor mans alterative / older alternative to punched banding strap, but is used a little less these days, because the big advantage of the banding is that it will remain in place in a fire so can be used to support cables in fire escape routes
