These are 2 assignment questions that i just cannot answer . Can someone please help....?
1. A mains operated room thermostat requires three conductors to enable it to operate correctly. Can you connect the thermostat to an existing two core and cpc cable?
2. What is the output voltage of an Insulation Resistance Tester which is required to test a 230 volt cirvuit?
