To clarify, if the minimum operating pressure at the meter is measured at 15 mbar
WP at the appliance of less that about 15 mbar
Although you are talking at crossed purposes as usual.
I will pass that on to the person looking into the energy supply infra structure for the proposed new settlement.like a teacher used to say , must try harder and you need to google harder
Out of curiosity what is your opinion / advice in the situation where the gas consumption at a housing estate was found to be peaking at more than twice the predicted amount. Prediction based on the developer's documention in the planning application.u either don't understand gas or ur as dangerous as he is!
If you think
If you think that it is a different figure then why don't you be helpful and quote what you think it is?
Technical Documnet TECHNICAL BULLETIN TB 0040 a (2010/09) which is in the public domain ( via Google of course )
And therein lies the problem
cessation
Came to light while researching the infra-structure needed to be put in place to enable a new settlement of between 2500 and 4500 houses to be built.
Bernard also forgot to mention that this is only permitted for 5% of the time
