2 'F' outlets for sky +
1 TV out
1 RF return to loft box
1 FM/DAB
1 Telephone
Comes in two types, one which requires 2 coax, and one which requires 3. Depends on the loft box used - the TV, Radio, and 1 sky signal is triplexed onto one coax, and the second sky and the RF return are either on seperate cables, or dualplexed onto just one second cable (clever, as one signal is going up and the other down!).
Don't like seeing walls covered like that - If the TV is going in the corner, would prefer some on one wall, and some on the other, or even some on top of the others.
TBH, as things progress, less and less power sockets are required these days due to everything being intergrated.
