thanks, assume the grey is a neutral then if it’s black grey brownPl = brown
sl = black
n = blue
Blue ??Pl = brown
sl = black
n = blue
There is only Brown is Line.Hi All,
What’s the standard use for Black Grey Brown when wiring a bathroom extractor?
3 core has grey brown black, so sleeve the grey with blue sleeving, tape ?Blue ??
Yes, if the Grey is being used as Neutral.3 core has grey brown black, so sleeve the grey with blue sleeving, tape ?
Yep, as EFLI said, IF it is being used as a neutral. (preferably sleeving, rather than 'tape')3 core has grey brown black, so sleeve the grey with blue sleeving, tape ?
They do - seemingly to avoid people 'getting confused' by the fact that, as you say, black used to be neutral in UK.A lot of people think that the Grey should be used for Neutral (but Black used to be Neutral in the UK).
Yes, #metoo.The logic of that reasoning somewhat escapes me!
You thought correctly - you almost seem to be suggesting that you now doubt yourself?And I thought it was brown phase 1, black phase 2, and grey phase 3, and blue neutral if there is on, and bare or green/yellow for earth.
Indeed, in the same way that the blue ('if there is one') should be sleeved it is is used as anything other than a neutral - but then you would be talking about a 4C+E cable, whereas this thread is about 3C+E.With a single phase supply should be brown and other wires sleeved to show what they are, with no sleeves one needs to test.
Presumably only in countries in which 'over-sleeving' is allowed?Many will use the black (sleeved brown of course) for the permanent line to match the convention used in Hager Klik LSC roses.
Of course. I was referring to the OP's question, based on his/her jurisdiction. It's far better to use correctly coloured cables though, without question.Presumably only in countries in which 'over-sleeving' is allowed?
