What is the prospective short circuit current between phases of a 3 phase supply
can you have sockets in the same room on different phases
It depends on the wiring resistance...
Why do you need to know?
The question you asked was about prospective short circuit current. These answers (at least three of them, and presumably also the fourth) are all voltages! I don't think you've looked at the same Q and A!it is one of the questions on the technical assessment i am doing as part of my electrical course the 4 possible answers are(1) twice the phase to neutral value ( 2) 500v ( 3) 230v (4) 3 times the phase to earth value
It's not that ususual. My house has different phases on each of three floors. I've gone to quite some lengths (some people would probably say unnecessarily) to keep the phases apart (e.g. by using ELV for cross-floor control circuits, even lighting control), but I think some people probably get unnecessarily nervous about this. It obviously makes sense not to have different phases (e.g. sockets) close to one another but, in the final analysis, 230V is almost as likely to kill as 400 (or 240V as 415V).I'd be reluctant to have them in the same house!can you have sockets in the same room on different phases
Do you think so?The correct answer is
The current that causes immediate tripping of the lowest rated OCPD ( over current protection device ) of the two OCPDs fiited on the phases involved.
But quoting that will make the OP look like a clever clogs and they are not liked.
Eh? The prospective fault current might not actually be adequate to produce 'immediate tripping' (tripping within the required disconnection times) of the OPDs - that's surely one of the reasons one needs to determine prospective fault currents?The correct answer is
It also might be a little difficult answering an MCQ in such termsBut quoting that will make the OP look like a clever clogs and they are not liked.
The PSCC is either measured directly if the tester can cope with 400v, i.e. the max value between L1-L2, L2-L3 or L3-L1.
If the tester cannot cope with 400v then the maximum L to N value may be doubled up and used.
