Can you help with this problem please?
I have just had delivered a professionally restored woodworking machine. It is a Wadkin 3 phase planer.
The company that restored it have done everything to bring it to new condition, and I am informed it works as it should. So for now maybe we will assume the machine is OK and the problem is me.
It has been re-wired and arrived with a 4 pin 32 amp plug. The problem is all my 3 phase machines have 5 pin plugs. I was told I could replace the 4 pin for a 5 pin plug, just don’t use the neutral pin, simply connect the three live wires and the earth, as some machines don’t need a neutral.
So I did that, but machine will not run, the motor starts momentarily, but will not run. My other machines work fine off the same socket.
I have had machines run in reverse when the phases are out, but not try to start and stop instantly.
But I moved the wires in the plug around anyway to switch around the phasing but it’s the same however it is wired. I can get it to try and start in forward and reverse, depends how I wire it.
What’s wrong please? Thank you.
