3rd Heat Exchanger in less than 3 years - Is this normal
deposits will not occure below 60 degree's c, but dont forget the powermax 155x trand=sfers heat through the plate heat x at over 60, then reduces it down with a blender valve!!
Quite so. How hot would you have the store in one of them, Jason?
Well in that case its obvious why the lime scale deposition is occuring!
Does the manufacturer make any recommendation for alternative settings for hard water areas?
Setting the store at 65 C should prevent lime scaling and may give just adequate HW preformance.
Tony Glazier
I seem to remember working on a Powermax this year, from memory it has a built-in thermal store and the secondary heat exchanger is copper, therefore the use of strong HCL should be resisted (probably best to use that on stainless steel only), your problem as the user would be how to recirculate weak acids (Sulphamic) in the DHW heat exchanger, hire a flushing pump perhaps, or buy/rent a baby powerflusher to use once a year when the flowrate starts to drop.
Apologies in advance if I've confused the model with another, it comes easier with age.
