4 reactors on fire!!!
ColJack said:
if the reaction has stopped, then why are the rods still heating up? they only get hot when the reaction is happening..
Unfortunately not. :( :( :( Fission can be stopped instantly by dropping the control rods but it accounts for only 80% of a reactor's power. The remaining 20% comes from the radioactive decay of the fission products which are overloaded with neutrons and thus highly unstable. It's this decay that heats up the rods and it can't be turned off. You have to keep on taking the heat out until it runs down.
The spent fuel rods pose a similar problem. They're spent only in the sense that they contain insufficient fissionable material to be worth using but the fission products are still breaking down. That's why they have to sit in cooling ponds for a long time.
There are quite a few things wrong with the design of the Japanese reactors. Firstly, water is a terrible choice of coolant:
1) If you lose the pressure, it boils and you lose your cooling. :shock: :shock: :shock:
2) It limits the operating temperature of the turbines which is not good for efficiency. Fossil fuel power stations can superheat their steam up to 900°C. This would create impossibly high pressures inside a water cooled reactor so they have to run at a rather pathetic 300°C. :( :( :(
3) Water absorbs the neutrons that are needed to sustain a fission reaction so you have to put extra fissionable material in. This is, arguably, its biggest shortcoming. If you must use water, it should at least be heavy water but, as far as I know, only Canadian reactors do this.
Water cooling was originally developed for submarines where space was at a premium. Sadly, it's now the most common choice for land based reactors because it's cheap. Moreover, the boiling water reactor, which is what the Japanese ones are, is the cheapest and nastiest of the lot. There isn't even a secondary heat exchanger in there. Radioactive steam goes directly to the turbines! :shock: :shock: :shock:
And then there's the cooling ponds for spent fuel rods. It would appear that the Japanese ones are kept just above the reactors (but outside the primary radiation shielding), ideally placed to be damaged in any reactor explosion. :roll: :roll: :roll:
There's a lot of misconception about spent fuel. I remember a survey in which a substantial fraction of the general public wouldn't go anywhere near a new fuel rod but would happily pick up a spent one. :lol: :lol: :lol: It's not just the decaying fission products you have to worry about. The greatest danger comes from long-lived heavy elements, including plutonium, which you get when you leave uranium stewing in a neutron soup. Plutonium isn't particularly radioactive but it is highly toxic, even in microgram quantities. You really don't want it being blown into the atmosphere.
So, to summarize:
1) Cheap, nasty reactor design.
2) Cooling plant not protected from tsunamis.
3) Spent fuel ponds not protected at all.
That's what you call an accident waiting to happen.
On a happier note, you might like to know that UK reactors are CO2 gas cooled. This allows for much higher operating temperatures (650°C) with no risk of boiling. Our only nuclear accident involved an air cooled reactor in which the graphite moderator caught fire, something that really should have been foreseen. :roll: :roll: :roll:
Tokyo Electric Power Company (TEPCO) - They do not bear too much scrutiny - inscrutable as they appear.
[url=http://www.csmonitor.com/World/Asia-Pacific/2011/0316/Reports-Lax-oversight-greed-preceded-Japan-nuclear-crisis]The CSM[/url] said:
...TEPCO has come under fire in the past for falsifying safety records at the Fukushima Daiichi plant. In 2002, according to The Wall Street Journal, TEPCO admitted to the Nuclear and Industrial Safety Agency that it had falsified the results of safety tests on the No. 1 reactor.
This was only one in a string of scandals and coverups to mar the Asia's biggest utility company. In 2007, the company initially said there was no release of radiation after an earthquake damaged its Kashiwazaki-Kariwa plant, but later admitted that radioactive water spilled into the Sea of Japan...
...Spent-fuel pools shielded only by outer reactor building. Spent-fuel pools at the plant sit in the upper reaches of the reactor buildings, near the top of the reactors so cranes have easy access to load and unload fuel.
Most of the radiation shielding at the reactors comes from the thick steel reactor vessel itself, which sits inside a steel-and-concrete containment structure. The upper reaches of reactor buildings represent the weakest barrier in the plant's "defense in depth" approach to keeping dangerous levels of radioactivity out of the environment...
I am betting bean counters and legislators will be ultimately to blame - But they, nor theirs, will be toiling in the danger zone - Therein lies one answer... Get 'em suited and boot 'em into the fray, they'll not be so keen to put profit before safety - if they should survive !
Overall source - (neat).
http://jpquake.wikispaces.com/Some+Good+Journalism
-0-
I think the Japs are going to get absolutely slaughtered by the Nuclear Power Nations, and others, for there stupid and cavalier way of building power stations without a thought of safety.
It doesn't take much thought to implement measures to take care of these problems and it appears they gave very little.
They as a nation of have brought shame on themselves for their stupidity.
They can be arrogant pigheaded plonkers at times and only get what they asked for.
The same thought the Americans gave, before using an Atom Bomb? That doesn’t seem to have stopped them from being the leaders in nuclear policing.
Blind leading the blind, comes to mind.
SALL, Leaders at the time of the end of WW2 gave a lot of thought to the atomic bomb. Had they not taken the decision to bomb Hiroshima, the war in the Pacific, could well have dragged on for months if not years. Don't forget who started the aggression in 1941.
Whether the USA should have carried on and subsequently bombed Nagasaki is open to debate though. Some historians feel the Japanese were ready to capitulate after Hiroshima and others think Nagasaki was a show of strength for the benefit of Russia..
I'm sure however, the use of atomic weapons did bring the war to an end and without them many more lives would have been lost, had the war continued.
SALL where do you think we would be now if Japan or Germany had invented and used the bomb first?
The Japanese energy industry are manipulative in the way they set themselves up and able to rebuff any public criticism about their conduct.
1. They are a major contributor to advertising in the media. So, any criticism by the media means a loss of revenue. Hence, the lack of transparency in the reporting of incidents.
2. They are a major contributor of jobs for the retiring government ministers etc..
My conclusion.......Tepco amongst others have got everything stitched up quite nicely. Hence their cavalier attitude to public safety. E.g. Their completely stupid and false reporting of the incident.
Tongue in cheek.....Since the Emperor has shown his displeasure this is a very serious kick up the backside for Japanese psyche. Unless they think he's a spent power as well.
Just don't eat any pasties that start growing 13 fingers , or an extra leg . :wink: :wink: :wink:
