Don't keep on.We disagree that glands need to be fitted to swa in every case, I think its misleading for future readers to think that thay can use swa without glands,
They can if the armour is not necessary. Do you earth metal capping?
Yes, one of the very few actual legal requirements is the need to 'notify' the Local Authority if/when installing a new circuit.can you elaborate on the need to inform the local authority that I am putting in a new cuircuit, are we saying building control??
In England and Wales, installation of a 'new circuit' always requires notification (i.e. involvement of LABC) unless the work is undertaken by a 'self-certifying' (actually 'self-notifying') electrician (i.e. one who is a member of a 'Competent Persons Scheme').can you elaborate on the need to inform the local authority that I am putting in a new cuircuit, are we saying building control??
That's simply not true. As SUNRAY frequently reminds us, glands are but one way of terminating SWA. Indeed, as he also points out (and illustrates) there are a number of commercial products available for use with SWA when traditional glands are not used.We disagree that glands need to be fitted to swa in every case, I think its misleading for future readers to think that thay can use swa without gland...
I've tried to drop this a few times.Don't keep on.
I've agreed with you already, you do things your way and I'll do them mine.That's simply not true. As SUNRAY frequently reminds us, glands are but one way of terminating SWA. Indeed, as he also points out (and illustrates) there are a number of commercial products available for use with SWA when traditional glands are not used.
It's because although this is a DIY forum, folk want the DIYer to do it to professional standards.Fair enough - I clearly did misunderstand.. However, as below, I don't think that materially alters my view.
Yes, it seems that he could do any of those things, and (as will presumably not surprise you) my personal inclination would be to suggest the last one.
It continues to rather amaze me that there have been 6-7 pages of discussion about the need (or otherwise) to earth something which, as things are, is (and always will be) totally untouchable. Even the bit of cable in the wall does not need earthed armour so long as (as is required) it is RCD-protected. Ironically, any approach which involved 'properly glanding' the SWA with a metal gland would (without a lot of additional hassle/work) actually make it effectively 'touchable'!
Kind Regards, John
As I keep saying, I'm not talking about what you or I would do - my concerns (for other readers of this thread) are that there should not be incorrect/misleading statements about what is 'right', 'wrong', 'mandated', 'compulsory' or whatever.I've agreed with you already, you do things your way and I'll do them mine.
As you say, no 'right' or 'wrong'. There is a common way in which SWA is terminated (with 'SWA glands') but, as I said, there are also other acceptable methods - and I am not away of any regulation/whatvere which expresses any view about the choice.No right or wrong, or am I wrong fitting glands I'm not sure now.
That's fair enough, but there does not seem to be universal agreement as to what constitutes "professional standards".It's because although this is a DIY forum, folk want the DIYer to do it to professional standards.
Ok I'll go with thatAs I keep saying, I'm not talking about what you or I would do - my concerns (for other readers of this thread) are that there should not be incorrect/misleading statements about what is 'right', 'wrong', 'mandated', 'compulsory' or whatever.
Kind Regards, John
Is that me? Hope not.That's fair enough, but there does not seem to be universal agreement as to what constitutes "professional standards".
At least one "professional electrician" (albeit retired) has been expressing a view which it sounds as if you would probably regard as "not up to professional standards".
Kind Regards, John
No. Are you also retired?Is that me? Hope not.
Certainly no hard feelings on my part!Anyway John we finally got to the bottom of it all, hopefully no hard feelings, keeps the brain ticking over for me anyway
I wish, not there yet.No. Are you also retired?
Good, me either, nice chattingCertainly no hard feelings on my part!
No, I assumed nothing. The person I was referring to explicitly indicates that he is retired!I wish, not there yet. I assumed you assumed as I said I was old
