- Joined
- 27 Jan 2008
- Messages
- 25,111
- Reaction score
- 2,922
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Good point raised by @flameport it says
This to my mind causes a problem, much depends on the consumer unit make and model, but getting a type B is expensive and not available as single width RCBO as far as I am aware. This advert says £114 and it seems to be three modular wide, for Wylex part number NSPE-5580 looking at £600.
Taking a chance with non type B is all well and good if it does not supply anything else, but don't want a fault on the AC stopping a second fault on a socket stopping it from tripping, so with that information there seems no way you can supply from the ring final, I was unaware of the RCD requirement.
soWhen installing the earth leakage protector, make sure it is compatible with the inverter (resistant to high frequency electric noise) to avoid unnecessary opening of the earth leakage protector.
RCD Type B: RCD for which tripping is achieved as for Type F and in addition:
(a) for residual sinusoidal alternating currents up to 1 kHz
