It seems I have a bit of a mess here then.
1. There is a double socket in the laundry which is, I think, on the ring main - it's on the ring main because there is a thick (4mm?) wire going in and one coming out.
2. Also come out of that double socket is a very short wire which goes to an FCU which feeds 2 exterior lights. This is OK, yes?
3. Also coming out that double socket is a single cable to a double socket. It's thinner than the ring main. The socket it's feeding isn't fused or anything. This isn't OK I think. Not sure why. I risk overloading the ring main? Or just overloading the spur?
Interested in solutions to bring this within spec and make it safe.
My issues:
It would be very difficult to alter anything OUTSIDE this room. Solid floors, all walls and ceilings are newly plastered and decorated. INSIDE the room a fair bit of freedom. Though there's an issue of getting cable through the worktop without making too much mess.
One of the sockets on the ring main is in use (boiler control) but the other is free. Presumably one of the appliances plugged directly into that would be optimal? And a second FCU for the other appliance?
