He's a twit.I've asked my electrician to make the system safe for a tumble dryer and washing machine to be used in the garage. His solution:
Garage consumer unit with RCD fed by the 2.5mm spur
No.1. Does this adequately protect the 2.5mm spur cable to the junction box
Yes, as it involves a CU. But as you're using an electrician it's irrelevant.2. Is this work notifiable
Hmmm - a B16 will pass 18A indefinitely, and will trip in 1 hour at 23.2A.3. Would connecting both washing machine and tumble dryer to one of the 16A MCB's be OK, assuming tumble dryer and washing machine are unlikely to draw more than 16A long-enough to trip the MCB, and that 2.5mm is OK to handle max. 16A
Tumble driers pull their rated current for the whole time they're on, or almost if they have an anti-crease finish.
What's wrong with extending the ring?4. If none of the above are OK, are there any other alternatives other than new ring or radial from the main house consumer unit
