Getting a 9.5kw shower fitted next Tuesday, and the installer says for a 9.5kw shower you "could get away with" 6mm cable to the main electrical board.
Now, I'm not so sure, and to be honest, I'm starting to wonder if the guy knows himself.
Local tradesman, probably fitted loads of the things, sounds like he knows his stuff over the phone, but when I asked if he will be using 10mm twin and earth cable for the installation, he says "Naa, 6mm is fine."
Now, I checked about online and couldn't get a answer but general opinion is use 10mm stuff - its rated to carry highter ampage etc etc.
Anyone point to BS Standards or building Regs on this stuff?
Any sparks in the room to advise?
The guy sounded spot on until he mentioned the 6mm cable being fine.
The cable used would be about 10 - 13 meters long.
I have read the Regs say for a 9.5 you need 10mm T+E and a 45A RCD.
The guy says 6mm and a 40A RCD.
Should I be concerned?
(Im in Scotland by the way so I dont think Part P applies)
Thanks.
Thanks.
