S
sparkyspike
Henley blocks are used to split the service cables in order to connect more than one consumer unit. It is advisable also to fit a main isolator which will turn off both CUs at once. This is fitted before the Henley blocks.
Is there not a spare way in the unprotected side of the CU where you could fit an RCBO to avoid the expense of having two CUs? (Not that there's anything wrong with the plan to have a seperate shower CU.)
