As an engineer that works on petrol pumps for a living, I can tell you zones are.
Zone 0;
• Within any access chamber or pit in which there are tanker delivery hose
connection point(s).
• Within an oil separator (petrol interceptor).
Zone 1;
• 1m radius around the road tanker delivery and vapour return hose connections
extending down to ground level.
• 1m radius along the delivery hose route from the tanker connection point(s) to
the tank connection point(s).
• 1m radius from a tank fill point (above ground)
• 1m radius from the edge the chamber if fill point is below ground.
• Within petrol tank access chambers which do not have tank fill points.
• 2m radius around tank venting point(s) which do not have a stage 1b vapour
recovery system.
• 1m radius around a venting point of an oil separator (petrol interceptor).
• Within the access chamber of an oil separator (petrol interceptor).
• Within a 4.1m radius of a petrol delivery hose connection on a dispenser (without
stage 2 vapour recovery).
Zone 2;
• 4m radius of tanker delivery hose connection point(s).
• 4m radius of above ground off set fill connection(s).
• 1 m radius around vapour return hose connection point.
• 2m radius around tank venting points where the site has stage 1b vapour
recovery installed.
• 2m radius from the edge of an oil separator (petrol interceptor) access chamber.
stage 2 vapour recovery in operation).
Zone 0;
Zone 1;
recovery system.
Zone 2;
recovery installed.
