Hi Guys, i have one of those fused spur sockets that is being used to power a plug socket that i wish to move... my question is this. do i have to keep the fused spur...could i just obtain a plug socket and wire it to the where the spur now is???
depends on the size of cable / design of cable runs. more info is required to advise you correctly.
how many cables in back of Fused Spur 2 or 3 sets ?
i just looked at my first post and it makes no sense so thought i would give a bit more info.
I have a 13a fused spur unit with three wire sets coming in at the back, that is powering a plug that will very soon be hidden by a new fireplace, and thus becoming useless. rather than move the plug socekt (which would involve lifting carpet etc) i thought the easiest thing to do would be to replace the fused spur unit with a plug socket.
so to do this..i guess i remove the cabling that is going to the spured socket and then simply wire the new plug socket into the ring. Leaving two wire sets the back of the new plug....does that make sense and can it be done
