- Joined
- 27 Jan 2008
- Messages
- 25,357
- Reaction score
- 2,979
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I remember there were two types of anti-freeze, one was alcohol based and it could evaporate faster than the water, so every year the hydrometer was used to check the strength, however the glycol stuff worked the other way, so if mixed the standard hydrometer did not work, there was a tester using the refractive index not sure if that worked with a mixture, but to top up one had to have a ready mixed coolant as you could not be sure what was already in the system.
Standard was 25% antifreeze, but our gritting wagons had 50%, it seems at 25% it can turn to slush although not freeze, so it stopped the core plugs popping but if engine worked hard before it had warmed up you could get hot spots.
