Sorry, yes i am talking about Electro Magnetic Fields or electrical interference, instead of ElectroMotive Forces.
I know in Electrical Electromotive Forces are discussed more, it relates to the principles behind motors and generators, wires cutting magnetic fields creating current in the wire, or current generated fields repelling wires or metal objects. In the case of the rings the live and neutral, as the current flows through the cable, it generates a field that rotates around the wire depending on the current directions. If the live and neutral flows from the same direction of the ring, the live wire with its own rotating field will be cancelled or greatly reduced by the neutral field generated by the return current.
In normal installation concerns problems with the ring are more relating to the safety of the installation, for instance fire from an overloaded ring, but if the ring is was not heavily loaded then the issue with electromagnetic fields well be present, but mostly invisible. A correctly installed installation will have its resistance measured and recorded, this is to make sure the line and neutral are balanced, but the house i am investigating was back in 1970, and i expect from some basic readings my neutral has higher resistance than the live.
I have an interest in this topic, my background before studying electrical installation was electrical and electronics. Im looking in to this issue as a practical experiment to see if some of the readings really account to faulty installation. Scientific research already shows that animals, people, and life forms are affected by magnetic fields and electronic communications transmissions. Its hows birds navigate long distances around the planet as well as bees navigate, using the earth magnetic field.
Also the 50Hz / 60Hz alternating current is within range of the human brain frequency states, have been shown to affect the human body. When the body rests its been recorded to slow, and the brain hibernates so to speak, so being surrounded by a 50Hz field which is only small number Hertz above what the brain is when we are most focused, could affect sleep, moods and general health. We are biological and electrical life forms after all.
When Newton was hit by the falling Apple he discovered gravity. It might be invisible, but if we jump, there is no denying we return to the ground. Also how Earth's magnetic field affects the rotation of water as flows down the drain, changes depending on what side of the equator your on.
ElectricsRanger
