Fair enough. It obviously must 'work' by virtue of capacitive coupling (presumably to earth, not neutral) from the device itself.Yes. (not a very good picture) ... I don't know how it works.
However, as I said, I'm rather surprised that it works - but, as I also said, given that it does work with what must be a very small capacitive coupling to earth, I would expect that, when it was being held (thereby probably substantially increasing the path to earth) it probably would indicate in response to very 'tenuous' voltages - such as those resulting from capacitive or inductive coupling between cables/conductors. As you go on to say ...
If it can do non-contact detection, it must be pretty 'sensitive' (much more sensitive than a 'contact' detector needs to be) - since there is an additional impedance (capacitive reactance) between the device's tip and the voltage source. That reinforces my suspicion that, when 'held and connected', it could probably easily light up in response to 'spurious' voltages (induced or capacitively coupled).Possibly - as it is also a non-contact detector when holding the tip (or touching the other end) - but then, don't use it for anything hazardous.
Kind Regards, John
