Fair enough. I remain a little surprised that they are apparently as 'reliable' as you are reporting, but I don't think I have anything new to say.They don't seem to do that.
Kind Regards, John
Good work chap- been a pain for you investigating that but at least now you won't be fretting about random bits of cable under the floor.
Just need to sort your meter cupboard out now.......
Time to grasp the nettle and do something about it- it isn't a DIY job, you may be able to save yourself some cash by buying the bits in yourself but that depends on the electrician you choose to do the work (I was lucky). Up here (Northeast) you'd be looking at £150 or so to regularise your existing setup, add another £50 or so to replace those 2 switch fuses with a nice modern CU with RCBOs in it. (That £150 assumes that no nasties emerge when the final circuits are tested). Don't worry too much about replacing the main CU on the right- as long as you're not adding things to it it is still acceptable. If you're lucky, your electricity supplier will fit an isolator after the meter (when they're called in to isolate so the work can be done)Yeah, I've been thinking about that....
WTF?I have always felt what feels like 50v on the backbox
WTF?I touched the earth wire on the switch cable (red/red/bare), and I felt what felt like about 50v.
WTF?Well, I did query the tingle.. My dad didn't think he could feel it.
WTF?About that "tingle"... Well, I can give you something to compare it to now.
A neon screwdriver / voltage tester. When it's on a Live wire and glowing, move your finger around on the contact on the end.. that buzz/tingle, is exactly what I was feeling on the metal faceplate and backbox
WTF?I'd probably attempt changing the tails myself.
WTF?I often change lightswitches and sockets without turning the power off.
I often change lightswitches and sockets without turning the power off. Carefully. Should I get my coat.. ?
If this is a wind up, then you've had your fun - now go away.
If it's not, then please down tools immediately, and get an electrician. You are completely out of your depth and have dangerouswiringworking practices.
