Accenta G3 question
Haha - yeah ok Page 16. So
Engineer code - 1 (for alarm test) - 6 (for walk test)
Then what am I looking for
the entry needs to be changed first, change it to 10 seconds rather than 30 it should speed things up.
I can see it can be set to 990 seconds, so if your using the orginal engineers code 9999, I am guessing thats what its been set to 990 seconds, about 15-17 minutes.
Ok - change entry time to 10 secs
This will be:
Prog - eng code - Prog - 1 - 4 - 0 - 1 - reset- reset- reset- reset
I think, agreed?
Right.
So I did the codes as discussed.
I then set the alarm and waited for it to arm.
I then opened the door - double beeps almost immediately then it started the siren.
I think this has worked
so you now need to think about how much entry time you need in blocks of 10, ie is 10 a little too quick when you have the shopping?
we know the siren works
nothing else as siren etc is working (unless you have a battery tester and a multimeter), you might want to adjust the time and then test it, 10 seconds is a little quick for some
Yeah I think it'll put it to 20.
10 is fine for me but perhaps not for the less nimble members of the household.
You've been very helpful - thanks. If you would like to nominate a charity (either here or on PM) I will make a donation.
