- Joined
- 27 Jan 2008
- Messages
- 24,922
- Reaction score
- 2,881
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Just taken delivery of a battery charger for my camera which has USA type two prong built in plug rated AC 100 - 240 volt 50/60 Hz and with it an adaptor marked 10A 250V for export only travel adaptor converting 13A to near anything with no fuse and no shutters.
I thought these were outlawed? I will use it in an extension lead as there is a fuse in plug of extension lead. There is a 12 - 24vdc input also which was one of the main reasons to buy but no indication as to if centre is pos or neg.
The one I got for the Nikon looked near identical to this one for Pentax and I am sure the cig lighter lead can be used for both. I have three battery chargers for cameras and phone and I am sure the others do not contain any fuse in the adaptor however other two the adaptor is unique to charger and could not be used for other items.
So keeping the adaptor for use just with the charger it came with is no difference than using the other two however it does raise another question.
Should we as a matter of course use multi way adaptors in our sockets for small items like chargers so as to:-
1) Ensure no strain due to weight of battery or built in switch mode power supply is placed on the socket.
2) Ensure there is always a 13A fuse in the supply.
OK safe in my hands I have enough knowledge to know where to use, and they are so tall works out well with charger being over the top of the plug facing it. From a British Supplier
DSTE Technology, Amazon Way, Fife. Maybe Scottish rules allow these items?
