- Joined
- 27 Jan 2008
- Messages
- 25,728
- Reaction score
- 3,049
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
This
and
type is good for the items which you regularly use in both locations.
This
also available with earth
better for items rarely used in both locations but these adaptors by Powerbreaker part no SCP3-B-13A at £2.15 each are not cheap and were you have no intention of using back where Schuko sockets are used may be better to change plug.
Under BS7671:2008 regulations the Schuko socket is not allowed in UK not sure on Ireland because it is reversible and when using the adaptors it is possible that neutral and line are reversed resulting in the switch not always isolating the supply fully. Items marked
will not likely to be a problem but class I items you may consider a plug change as safest method.
This
