It's my experience - in a workshop with a variety of machinery including DOL started motors (compressor is 3hp, I suspect the saw bench is as well), MIG and stick welders, I don't recall having blown a fuse or tripped the breaker (rewirable fuse in the garage, B32 MCB in the house). But I do recall a few occasions* where the RCD (at the garage end of the supply) has tripped.
* OK, most of these have been due to (we assume) damp in outside lights.
I think that footnote is important'. I am struggling to personally recall any occasion on which a power tool/machine has tripped an RCD but, as you say, RCD trips due to external lighting etc. do occasionally happen.
IF one did as you suggest, and
IF those external lights were supplied by the garage/whatever 'lighting circuit', then that would surely create an even more dangerous situation? - the garage/workshop lights would go out, but machinery/tools would carry on functioning normally. If lighting and sockets circuits had a common protective device, at least the lighting fault would also take out the supply to the tools/machine, so one would only have to wait (in the dark) for them to 'spin down' for the environment to become fairly 'safe'.
And it doesn't have to be while actually using a tool. Having to navigate the workshop in the dark, when you may have bits of work in progress, cables, hoses, etc lying around is a significant hazard.
True - but, as above, provided lights and sockets were
not on separate RCDs, one would only have to wait (in the dark) for everything to 'spin down'.
There are lots of things that make sense but aren't commonly done.
Indeed - but, as I think I have illustrated above, there are definite 'swings and roundabouts' issues to be considered when deciding what
does "make [more] sense".
As you point out, emergency lighting would be "a good idea", but I suspect that in most domestic environments, they'd get even less attention to maintenance than smoke detectors
Agreed. However, there are ways in which one can, if one wants, attempt to compensate for that aspect of human nature. Many moons ago, I devised an "emergency light" which had a delay (about 30secs IIRC) on 'switch on', with the permanent live feed disconnected during that delay period. Hence, if the (battery) light did not come on immediately one switched the light on, one knew that the unit required attention!
Kind Regards, John
