Great will take a look, assume its better product than my plumbers recomendation?Intergas Eco RF 24 will talk directly with the Honeywell so no wiring. Just a 3npin plug on the boiler.
24 KW combi's fitted by the thousands around Slough in Granny annexes and rented out
Why would u want the nonsense of cylinders and electric is tosh as said before and again Telly Tony re-inventing the wheel
Nest Hive and also Honeywell on the Vaillant boiler as recommended by your installer and surveyed by him is quite adequate and a better option then listening to someone on an internet forum
That is quite true!
But many ( most ? ) exceed the gas supply capacity of the meter!
There is the driving instructor there who has THREE 24 kW boilers all on one meter.
But your not a real gas man!Your calcs seem a bit too rough.
Cooking curry and chapatti needs more heat that gently boiling some potatos ( aloo )
My calcs hardly cover two 24 kW boilers and the cookers.
Good job , because you do not have any, and you havent a clue what you are talking aboutThe rear garden annexes in Slough and Southall are all classed as domestic and so do not need any catering gas competencies.
There is not one word there I disagree with Lee from you post
