AUDIBLE INTRUDER ALARMS FORM A
NOTIFICATION TO POLICE OF NOMINATED KEYHOLDERS
Notes
i. The ‘Control of Noise (Code of Practice on Noise from Audible Intruder Alarms) Order 1981 (Statutory Instrument 1981 1829) gives guidance on methods for reducing the incidence of nuisance caused by the ringing of alarms. If you permit your alarm to ring unnecessarily action may be taken against you under section 80 of the Environmental Protection Act 1990. It is therefore in your own interest to adhere to the procedures set out in the code of practice, which can be purchased at Government bookshops or through booksellers.
ii. Paragraph 5 of the code of practice states that the alarm-holder should, within 48 hours of installing a new alarm system or of taking over an existing one, notify the local police of the names, addresses and telephone numbers of at least 2 keyholders and that the alarm-holder should, at the same time, notify the local environmental health authority that the alarm has been newly installed or that he has taken over responsibility for an existing alarm system. The code also states that alarm-holders should notify changes in nominated key-holders to the police within 24 hours.
This is Bradford city councils take - it references the code of practice but does not make it a requirement.
Leeds council below also have registration as a voluntary act
When burglar alarms go wrong, they can cause annoyance if they continue to sound, especially late at night. All alarms should have an automatic cut-out after 20 minutes. But if an alarm does not cut out or cuts out briefly then repeatedly continues to sound this means it may have developed a fault.
The householder or premises occupier is responsible for ensuring the alarm is maintained in good working order. If an alarm is causing nuisance and the owner cannot be located it may be disconnected by the Environmental Protection Team. The expense of doing this can be quite considerable (usually between £200 and £300) and will be charged back to the owner.
In order to help prevent this situation we have an Alarm Keyholder Details Registration Scheme. You can register the name(s) of emergency key holders for your alarm so if it sounds and cause a nuisance we will try the contacts you provide so that they can come and switch it off.
The keyholder registration form on this page can be completed electronically, saved and emailed back to us at
[email protected]. Please contact us if you have any difficulty with the form.
