Do you think that would be better for her needs? Seems bigger and bulkier than a circular saw...but more sturdy. Is that the main benefit?
there are quite a few other makes, but no expert hereNo, it doesn't have to be the Dewalt at all
not usually ,Is a mitre saw and a chop saw the same thing? (Sorry!)
I've just done some digging to try and find out more info..she doesn't have any other power tools so it can be any brand. She wants to make things like wall panelling, planters, general decor type projects around the house.
I (respectfully) suspect that she may not be aware of the limitations of circular saws. If for example, she purchases a 3" bit of timber and wants to rip it down to 2", whilst it is possible with a circular saw, it is (potentially) much safer and easier with a table saw. If she wants to cut square ends on lengths of timber a chop saw would be better. If she wants cut a full sheet of MDF in half she can use the circular saw but will need to put something sacrificial under it and possibly use a clamped straight edge as a guide.
For a DIYer who wants a circular saw to cut sheet materials, I would probably recommend a plunge type saw with a guide rail that it sits on. But she seems to do much more than that. You say she has no other power tools, do you mean she doesn't have a cordless drill? If not once she cuts the timber, how will she assemble it?
Hand saws aside, if I could only ever own one type of powered saw, I would probably opt for a jigsaw. A couple of years ago, I used my jigsaw with the guide rail attachment to cut some 18mm 8ft lengths of plywood for a log cabin floor (my plunge saw was elsewhere). The cuts were accurate to 0.5mm. That said, it would be rubbish at cutting accurate ends on 3*3 inch timber, as would a circular saw in the hands of a DIYer.
Sorry, I am not trying to muddy the waters (even though I have).
That may dictate the cordless brand she goes forShe is going to get a drill and perhaps some others bits
I use a drill/impact driver a lot for DIY around the houseShe wants to make things like wall panelling, planters, general decor type projects around the house.
