- Joined
- 16 Jul 2017
- Messages
- 3
- Reaction score
- 0
- Country
Hi all - new post.
My old property is rented and was a new build in 2004.
It has a Glowworm Micron 70FF boiler and over the years I've had British Gas out 2 or 3 times to repair it.
The boiler was serviced after the last tenant moved out in Oct 16 and has only been fired up a couple of times since for testing.
Recently ahead of a new tenant moving in this week, I tested it again and found it wouldn't fire up with the two LEDs flashing.
I re-signed to British Gas for a £99 repair plus service contract and the engineer called today.
The engineer took the boiler apart and found there to be a lot of soot inside the boiler (coincidentally that was also the case when serviced last October).
It has a rear flue which he advised is telescopic but had seized and hadn't been installed correctly.
He said the part (I assume the flue) is no longer available and that the boiler would need to be replaced.
On reflection, and having done some searching, I'd be surprised if the part isn't available but wanted to seek some expert views if you could kindly comment as I need to make a decision on getting a second opinion from an engineer or just go ahead ahead and swallow the cost of a new boiler ahead of the new tenants moving in?
Many thanks.
Many thanks.
