tenant needing advice please
Just out of interest, have you got your 'pink copy' of the gas safety certificate for this boiler. This should show you who and when checked it last.
Hi tryitandsee
The boiler was checked by bg on 8th sept.
They stated a new boiler was recomended due to parts no longer being available so they could not repair it and they gave him a cost to replace the boiler and pipe work as not a certain mm so would need replacing also.
The pink slip was then given to the landlord when he was given the quote. The landlord then told me what he intended to do after bg left and I am still waiting for him to do the work over 2 months later.
Two months is a ridiculous amount of time to wait for a repair.
Difficult one to speed up the Landlords response. He obviously feels put out at the thought of paying out for a new boiler, that he thinks can be repaired. I guess this boiler is technically gas safe, but does not have the control it was designed with.
I assume you have got your deposit with the DPS (Deposit Protection Service) or some other organisation. This can be disputed with them if you feel you are paying more in heating over and above what it should be because of non working controls etc. All time consuming and not sorting your immediate problem!
A good Landlord will normally have a heating engineer to keep things going, but this guy appears not to have.
If your happy with the property and all else, perhaps more persuasion to the Landlord is necessary. Perhaps a letter to Landlord recording your problem giving him a time to fix and then stop paying your 'extra over costs' from the rent each month. This may sharpen his decision making :D
