Certainly nothing can argue with that logic.....I wonder if the recent switch to electric power steering pumps was similarly inspired and maybe A/C systems will go the same way eventually.
I'm testing my A1 with the system off and on to see if there's any difference.
John
Yes, it's all to do with power management. The manufacturers are under pressure to reduce CO2 emissions (bit fines from the European Commission if they don't!) and maximise fuel economy (consumer pressure). Engine-driven power steering isn't that efficient because the pump needs to be sized so that it can deliver full flow when the engine is idling (where most manoeuvring is done and demand is highest), and that means they're turning WAY too fast when the engine is running at more normal driving speeds, just "wasting" the pressure through the relief valve and back to the reservoir. The electric steering pumps can deliver flow (when needed) irrespective of engine speed. The same is true of water pumps (with the added advantage that you can then run the water pump with the engine off and stay warm in the car for 15 minutes or so.
I think the big problem with aircon is that the demands on the alternator from all these other electrically-driven systems that used to be mechanical. For a while now, manufacturers have been wondering about going to 24 or even 48 volt electrical systems because the cabling required to deliver this much power at 12V is really heavy. The problem is that there's just SO much 12V stuff around!
Electric vehicles obviously have electrically driven aircon pumps, so it must be possible, it's just a question of whether it's the most efficient way of doing it on conventionally-engined vehicles.
How were you going to do the tests on you Audi? In the past, I've found setting the trip computer to display instantaneous MPG and watching the figure as you switch on the AC to be not very accurate. Too many things change too easily on the road. Also, when first switched on, the pump will run continuously until the anti-icing feature kicks-in and switches it off. In this weather, that could be less than a minute! All I can suggest is that you find a bit of constant-speed motorway and zero the average consumption display, then drive (say) 20 miles with the aircon on, followed by (ideally) the same 20 miles in the same direction with it switched off and see if you can get a difference in average consumption. On top of that, you'd really need to be able to repeat it 3 times and get consistent differences each time, but it's a hell of a task without the controlled environment of a rolling road emissions lab. Part of the problem (especially in this weather) is that the differences you'd be looking for would be less (I reckon!) than the accuracy of the trip computer.
