Hi guys,
Wonder if you might be able to help me.
I went to do a job recently involving the addition of 2 radiators in a house. The job was easy enough, however when I came to recommission the system I’ve hit a couple of fairly major problems. These are:
- The newly installed radiators aren’t heating
- One of the originally installed radiators isn’t getting hot
I thoroughly checked the system and believe that an air lock is probably the cause. After a couple of hours the flow to the radiators was slowly getting warmer, however I had to leave before any improvement in heat was experienced. I’ve fully bled the system including the pump and have not changed any of the other system settings other than turning off the timer and boiler during installation. In case it matters, it’s a Glow Worm Hideaway100B boiler.
One thing I noticed was that the system had been generally poorly installed, an example of which being the 2-way motorised port valve was located on the return of the hot water cylinder coil, pipes into soldered fittings not fully inserted, and the layout could have been better planned. Drain cocks are present on all of the radiators.
The customer called yesterday to say that there was still no heat. I’m due to go and investigate but to be honest I’m at a total loss. I have produced some diagrams to show the problem (and set-up)
Old set up
New set up
Any assistance would be great, let me know if you require further information. I’ve posted on other forums but not had too much luck!
Graham
Old set up
New set up
Graham
