Alarm Power Circuit
3 Sep 2006
Kent
If a Alarm has has a transformer plug, to be able to have it on it's own circuit, can I do a radial circuit from the CCU to a single gang socket outlet in 2.5mm T+E :?:
And what size MCB should I put it on a 6Amp one or a 16Amp one :?:
6 amp would give about 1 and a qarter kilowatts
16 amp would give about 3 kilowatts
How big is the transformer ?
6 amps is the logical answer if nothing else is being powered on that radial
On the other hand, if it's a socket circuit in 2.5mm, you could reasonably give it a 16A or 20A MCB on the grounds that the plug itself is appropriately fused. That way you can use the socket for something else when the fancy takes you. Or you could fit an FCU when you buy a proper alarm.
breezer said:
i should point out that any good alarm does not plug in
It is a proper wired alarm with outside sounder, & PIRs inside the house.
If it's a plug in alarm then it's not what we'd call a proper alarm. Proper alarm are wired to an unswitched non indicating fcu as per regs. My guess it's a toys r us system from B and Q or the like.
