Rewiring Shed
Yes I have done plastic conduit before, at college in the workshop, doing a ring final & a 3 way switched, 3 lamp lighting circuit, in it.
Here are some more pictures of what I have done so far:
The wiring to the Grid Switch:
Grid switch wires:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00137.jpg
Earth to Grid switch back box:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00139.jpg
Wires to fed the 2 outside JBs:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00170.jpg
Outside JBs wires:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00169.jpg
25mm bend with wires in:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00171.jpg
25mm tee & bend with wires in:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00172.jpg
Close up of 1st Grid wiring:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00174.jpg
Close up of 1st Grid wiring (view 2):
http://i167.photobucket.com/albums/u125/mdbalson/DSC00175.jpg
1st Grid in place:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00176.jpg
Wires to outside JBs:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00179.jpg
Close up of 2nd grid wiring:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00177.jpg
Close up 3rd grid wiring:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00178.jpg
Close up of 2nd & 3rd grid wiring:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00180.jpg
Wires to 5 amp round pin socket (for pond lights):
http://i167.photobucket.com/albums/u125/mdbalson/DSC00182.jpg
Close up of round pin wires:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00184.jpg
The finished 5 amp round pin socket:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00187.jpg
All 3 grids in place:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00183.jpg
The finished grid switch:
http://i167.photobucket.com/albums/u125/mdbalson/DSC00188.jpg
Looks as if you have been usding G&Y Earth Identification sticky tape round non-earth wires, and blue tape on brown wires,and red tape on blue wires.
A good tip is to lay in a good stock of White tape for holding things together so you are not tempted to "identify" things wrongly. It is also useful for making labels, with a permanent marker.
I hate to see electricians who have a roll of sticky G&Y tape handy and use it round all sorts of things that are not earthed.
JohnD said:
Looks as if you have been using G&Y Earth Identification sticky tape round non-earth wires, and blue tape on brown wires,and red tape on blue wires.
The tape is so that I know what wire is for what thing
I know that:
  • The 2 G/Y taped wires, are the L & N for the pond pump
    The 2 Blue taped wires, are the L & N for the 6 LV Post lights
    The 2 Red taped wires, are the L & N for the side path LV lights
    The 2 untaped wires, are the L & N for the summer House light
I understand what you wanted to use the tape for.
But you surely don't think it's right?
What does red sleeving or tape mean on a lighting circuit? "Switched Live" or "the path lamps?" What does G&Y mean? "Earthed" or "the pond pump?"
Just had a peep at the most recent pics, will have a peep at the earlier ones later ;) .
Outside JB, you show the conduit single wires coming through the wall unprotected, have you made good? They should really be inside conduit as they pass through the wall and into the accessory. Have you solvent glued the joints in the conduit? Pond pump socket, is the pond pump outdoors? If so is there RCD protection for it?
There is RCD protection in the shed CCU
The JBs are for:
JB 1:
Pond Pump & 6 LV Post Lights
JB 2:
Side Path LV Lights & Summer House Light
The 5 amp Round Pin Socket is for the Pond Lights
Yeah, though I understand where ricicle is coming from, trawling through 5 pages is a bit of a pain!! Maybe start a new topic? I take it you are a C&G pupil?
It doesn't matter what the outside JBs are for, are they and the wiring system to them selected and erected correctly? I don't like the idea of the conduit singles going through the wooden structure without additional protection i.e. drilling the hole big enough and running a conduit through.
There is conduit present on the inside, it goes into the hole, perhaps this will be added in his next post :LOL:
