Now how it senses jamming I do not know.
If you are installing these and also advising customers about their use then you should make the effort to obtain a basic knowledge of jamming and how it will affect the systems you are installing.
Jamming of a radio controlled device is most commonly detected by the radio receiver receiving a signal on the radio frequency that does not match the protocol of the system. Or in other words if the radio channel is continuously busy but no valid or understandable data is being received then the channel is being jammed.
If continuous then it is jamming. if intermittant then it is commonly referred to as blocking. Blocking frequently happens as the result of another legal system nearby using the radio channel. This could be another alarm system or a vehicle key fob or any other equipment that is allowed to legally operate on that radio channel.
Blocking should not be a problem as the system can retry when the blocking signal has ended.
The problem for the equipment design team is to decide what is blocking and can be ignored ( other than re-transmitting the message ) and what is jamming and has to create an alarm.
Then there is random jamming and "informed" jamming.
Random has garbage as data messages and therefore easy to recognise as jamming.
Informed has data messages that the sytem will see as valid messages for other modules in the system and therefore cannot immediately be identified as jamming. The designer has to make the system able to recognise when infomed jamming is occuring. This is further complicated if one or more similar alarm systems are operating close together. Genuine messages from one system will affect the other(s) and the decisions about jamming, blocking or acceptable other system messages become more compromised.
A system that works well today may become un-reliable or even un-usable if a neighbour then installs a wireless system. Provide his system is operating correctly you cannot ask him to stop using it.
In short, if it possible to install a wired system then choose wired.
