- Joined
- 27 Jan 2008
- Messages
- 25,755
- Reaction score
- 3,054
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
If I am reading it correct the residual direct current detecting device (RDC-DD) trips the supply, so not talking about normal operation but fault conditions. I know some RCD's don't actually switch the supply, they send or remove a supply to for example a moulded breaker. So would think the RDC-DD could do the same, it may detect the current but not do the actual switching. An ELCB is clearly a circuit breaker, but an RCD is just a device, it may not do the breaking of the supply.
I have not got the 18th Edition, so don't know what an EV is defined as, one would think "Electric Vehicle" I have worked a lot on fork lifts, and the chargers would not cause any DC on the line, it would not pass through the transformer, the same applies to Milk Floats, I suppose both the Mobility scooter and the ebike are also electric vehicles, even a golf trolley, and there were no instructions with the Mobility Scooter or the ebike as to what type of RCD should be used, and clearly there is no RDC-DD built into the charger, both are switch mode so may be a case for not using a type AC, but I would have thought the main point is where the electric vehicle is charged, a caravan in a show room can be supplied with a TN-C-S supply, only when on a
caravan / camping parks and similar locations does it need a TT or TN-S supply.
The problem with the electric powered car was it is often charged to close to premises with a TN-C-S supply to be able to make it a TT supply with an acceptable gradient. I do not charge the ebike battery or mobility scooter battery outside, and I don't have a RDC-DD or type B RCD are you saying my home would fail an EICR because I have a mobility scooter? I am sure it would not, so must be a different definition to EV to being simply an electric vehicle.
