- Joined
- 11 Jan 2004
- Messages
- 44,496
- Reaction score
- 3,031
- Country
Easy.....stop using the b@stards and install sensible radials instead.Ring circuit conundrum - what to do?
That wouldn't surprise me.Type F will become the go-to type as they are suitable for all types of equipment.
Undoubtedly. However, for a start, as I recently wrote about the introduction of RCDs, the prices won't start to plummet until the first few million people have had to pay seriously exorbitant prices for them.Once enough are made, like everything the price will plummet.
Dunno.Type F will become the go-to type as they are suitable for all types of equipment.
EG, 5G phones were 4 figures when 5G was first available.
Now the cheapest 5G phone is around 200 quid.
Yeah but, no but - I have (did).Easy.....stop using the b@stards and install sensible radials instead.
Type B, surely?Type F will become the go-to type as they are suitable for all types of equipment.
Indeed. It's probably too far back for anyone to remember, but back on 'page 1' I posted the relevant bit of BS7671 which explains about these different 'Types'.Yeah, misunderstood some bumf I got from the IET. As you say, type B covers all scenarios.
Indeed, except that regulations have almost completely trumped any thoughts about that "if".Your first hurdle is probably the highest. But if you've decided that yes, RCDs are good things to have, the issue then is "what type(s)?".
Agreed, up to a point - but those "useful examples" are more-or-less the 'usual list', and get me no nearer to understanding the 'chapter and verse' of the facts behind all this.The Wiring Matters article has useful examples, and the "extras" of Type B over F seem to be mostly of interest to commercial/industrial environments. EV chargers are often self-sufficient for earth leakage monitoring/protection, and I'm not sure how PV as distinct from inverters works - what would an RCD between PV panels and an inverter do?
Essentially true. However, it remains the case that a high proportion of those 'on offer' are Type ACs.Type A over AC? Probably a no brainer if you have decided you'd like RCDs, the price difference is minimal.
I suppose that makes sense, but Type Fs are currently far from 'easy' to actually find (quite apart from the price, when one does find them.Type F.... Probably worth checking the MIs for new appliances,
I'm not sure it's necessarily that simple (even if one knows 'under which loads' to test). Provided one tests with the appropriate loads connected, that should address the possibility that a ('in normal service') DC component might prevent the device operating in response to an (AC) L-N imbalance due to a fault. However, if, as above, we are also talking about the possibility of a DC imbalance current due to a fault, then I presume that standard (present-day) testing procedures would not be able to confirm that the device trips under such circumstances?... and testing RCDs under load, as the problem is not "false positives", it's "false negatives", so if you'd rather like to have ones which work...
As has been discussed, if you really wanted to "cover all eventualities", it would presumably have to be a Type B (with the attendant cost implications, at least at present)?.... Obviously having domestic sockets RCD protected is a good idea, so I can see it becoming standard to fit type F to at least socket circuits to cover all eventualities.
