Many thanks Boilerman.
Do you think the pump is ok then because the hot water works fine?
I didnt think the pump had any use with the domestic hot water, i presumed (obviously a mistake) that the water went through the system under its own pressure.....
I have a day off tomorrow and will look into whether there is a filter on the return line that is blocked, i suppose by flushing the system i may have forced more crud to sit in this filter...
There is definately air trapped somewhere in the boiler and because it is higher than any of the rads and pipework i'm at a loss of how to shift it...
Someone mentioned to me the diverter valve might need servicing, is this a feasable cause of my problem?
Would certainly be cheaper....
