Altered header pressure resulted in reduced capacity
I pressed the ball down to allow as much water before reaching overflow pipe. Depth 8”/20cm. No water exited the vent.
If i did extend the vent higher all i’d be adding is a pipe with air in it….
Edit the knurled cap is a lid, a white blank under it in the ball valve assembly.
Think you try your original plan of upping the cold water feed to hot tank and take it from there. Let us know how you get on
