OP, your one looks a bit well made, and I presume it is well regulated so should run your 5watt led bulbs without any undue flicker, go for it and have a go and but remember that power supply is for a maximum load of 5 amps which means you could effectively run 10 LED bulbs in parallel with just that one electronic transformer as it is often referred to.
In either case, you have nothing to worry about, if your LEDs run flicker free, you are winner, if not then you need to worry about getting the right one for LEDs
I have wound transformer, not encapsulated which is rated at 25VA, and it weighs almost 1 kilo, so by that token a 75VA would weigh 1.5Kg
