Brilliant, Not bad at all, took you just under an hour! now I have been looking one of these LED lights, and found some amusing results, as I was trying to find out why they start flickering after about 5 minutes, using electronic transformer, and here is what I found:
first the characteristics, if you apply straight 12 DC from a bench power supply they draw 420mA , hence why they are called 5Watt, as 12 x.42 =5W
Now strange things start happening when you lower the voltage, ( well not quite strange for me as I can explain) these LED Lights clearly state not dimmable, so lowering voltage does not reduce brightness as one would expected in simple LED circuits with a current limit resistor.
So these particular LED lights seem to use a switched mode built in power supply to further regulate the current and voltage required to drive these LED lamps.
As the input voltage goes down, the internal circuit compensate for a lower supply voltage and starts to draw more current to maintain a constant power (product of voltage and current) so the light intensity remains very constant.
LEDs with a simple resistor will dim LEDs as the voltage is varied, since the current through the resistor is proportional to voltage across it. So these constant Power LEDs have built in circuit and one can hear it uses a switched mode operation as its interaction can be heard on a MW radio and the intermediate signal between the radio receiver and the LED light can be heard to vary in pitch as you turn the voltage up or down, I tried to go all the way up to 16Volts and it was drawing just over 300mA and did not fancy taking it any higher, and the Light remained very constant so from about 6volts to all the way to about 16v the light intensity did not change.
So these Enlite LED lights have a complex circuit inside to compensate for voltage drop, and that is the reason why electronic transformers are not suitable as the two switched mode power supply circuits can clash with one another, their switching frequencies can interfere with each other and thus start to flicker.
And you can see why they flicker for a while and then go steady as the two chopping circuits one in the LED lamp and the other in the electronic transformer starts to interact with one another, as the two switching frequencies phase in and phase out, so the flickering comes and goes in waves.
16.00v - 310mA (Absolute maximum voltage before expected destruction)
12.00v - 420mA
11.50v - 440mA
11.00v - 460mA
10.50v - 480mA
10.00v - 510mA
09.50v - 540mA
09.00v - 580mA
08.50v - 620mA
08.00v - 670mA
07.50v - 720mA
07.00v - 800mA
06.50v - 870mA
06.00v - 1000mA (1 Amp)
05.50v - 1160mA
05.30v Starts flickering and then any further reduction in voltage goes out completely
The bulb tested was MR16 brand name ENLITE, with 4000K colour temperature (bright white) 60 degrees spread and cost £4.90 each.
More technical data on this site;
http://www.ukelectricalsupplies.com...qxyrhkx8ozquAg04PVzHpyWCteH5ed-ngQaAoN48P8HAQ
