You seem to be clouding the issue by wanting to heat a hot cylinder.
can you leave the immersion off and then run the boiler on HW only and see what the flow and return temps are at the boiler?
I dont suppose you moved a valve under the boiler immediately before this problem arose did you?
Do they have plastic knobs on metal shafts? You could try taking off the knobs and see if ths shaft slots are in the expected positions.
Tony
Tony
