I don't see why we shouldn't answer this one. If the moderator is concerned that opinions expressed here might be cited in a legal conflict and get the site in trouble, we might as well give up.
It's the plumbers responsibility to check that the incoming main will provide sufficient flow of water to whatever appliances he's installing. There are other ways round it than fitting an accumulator, such as a large storage tank and pump.
I have just refused to fit an unvented cylinder where the mains pressure is 2 bar and the supply pipe is 15mm. The total cold mains flows in the house add up to about 18 litres per minute. That's marginal for just one shower. What clinched it was that they currently use a 3.5 bar shower pump, so would have been disappointed.
You can't get more out of a cylinder than you put in - an accumulator doesn't break that rule but it does maintain a better-than-mains flow for a limited period/volume.
